Have you performed a factory reset on your phone? That solves a multitude of upgrade problems.
check your account settings and make sure your email is synced to your account
How do I do that without losing everthing?
Hi Kra_z_nic,
Please go to your Gmail account on the web, and check Contacts - it's on the left side of the page.
If your contacts are on Google web, you're all set for those - but if they are on your phone only, you will need to use your contacts/people app on your phone to first export them to your sd card, and then import them back after the reset. Your DX pals here will have to give you the play-by-play on how to do that, I don't have your phone in particular.
You can backup your apps and SMS for free, look for these in the Market - Astro File Manager and SMS Backup.
You can also consider a really nice comprehensive backup tool for a few bucks, many people prefer MyBackup Pro.
And - there's yet another solution that may be open to you.
Go into your settings, Applications (or Application Management, it varies by name per phone model but it's the same tool) - and find the Market listed under All Apps. Click on that.
You may find that you can uninstall the update and go back to the way things were before. It won't remove your Market - just the update.
So, I think you have a lot of options that will help to your specific question.
I also think things are little confusing in the discussion here, because I thought the discussion was supposed to be about how to get this Market happening and how to restore some basic functions here.
Rooting is great, it's cool, it's wonderful - but it's something you do when you want to - if you have to root to make something basic in Android work, there's a big problem elsewhere.
And I don't think the Market has big problems only solvable by root.
Root just gives you access to more backup techniques where this particular problem is concerned - so, please decide on the path that you feel is best for you.
PS - My personal opinion - and I could be wrong, it's just my opinion - is that RichSz probably nailed the solution to problem right off. In my personal experience, factory/data reset is something I've just learned to do after any big update - I always have update troubles, that always fixes it for me.
Hope this helps, please let me know!
