skyscraper38
Can someone point me in the direction of the best way to go back to stock 2.1 on my motorola droid. Without losing all my things. Im just wanting to go back for right now.
Thanks.
Thanks.
What all will I lose?
Im just wanting to go back, if i have to lose some things i guess im willing too.
well you would loose all your settings and app data. All your contacts are linked to your gmail account so those would be retained. Apps also would also be redownloaded automatically by the market and even if they werent you could do this manually.
With what I am thinking you would be able to save your app data if it worked
rom manager has a stock 2.1 no root rom. If you dont have rom manager it is free from the market.
Where can i find the downloads to 2.0.1 and 2.1?
Best way back to stock is an sbf its detailed here
http://androidforums.com/all-things...-currently-under-construction.html#post780704
My idea for getting back to stock and saving app data is this. Its going to sound very backwards at one point but stick with me.
First backup all your apps and app data with Titanium Backup.
Then sbf back to 2.0.1
Then root your 2.0.1 setup
Restore your apps and app data with titanium backup.
Then reboot into recovery and use adb to get rid of su and superuser.apk
Finally force the 2.1 update.
The 2.1 update will put the stock recovery back. I cant think of anything else that would be left behind from rooting.
ok i have a problem i installed an update.zip that was for 2.0.1 and now i get lots of force closes with a black background and white notification bar and i cant do anything.
heres where i followed:
Manually Return to Stock Android 2.0.1 - Droid Life: A Droid Community Blog
I believe i have sprecovery but im not sure, but i can get into it. do i need to wipe data/factory reset?
