beastinbolts
Android Expert
What steps.did you take or method did you use.
so still having problems with this..... I found a zip that might help you.. awesome XDA asop fixes all in one I will post a link in a monent
opps sorry I miss spoke it only comes with the vvm fix...... I am about to flash a different asop rom and will have to do the gps fix my self... while I am doing mine do yours and I'll walk you through it kool
ok no probelm when you get your sd card post back and I will give you the link
Hey i just noticed your thanks is at three............???? you need to start thanking these people that have been helping you....all of the problems you have had and the time people are spending answering your question should bare more thanks from you.... just FYI
Thats very strange because just yesturday I thanked ocean twice and have thanked others as well as you many more than just three times
hey sickevo user since you dont have to wait for the zip here ya go gapps-evo-20110504-vm.zip this will fix your vvm
Well guess I miss spoke again.. this zip. Does do the GPS fix..... so now your set.
Ya ...install. from SD card[/QUOT
Ok and than do have run it lik an app or just open gmaps see ifbit opens. Will it matervif already have entered the mls code in my sense rom.
Na just reboot and your good to go
have you tried the gps fix not the app?
1.make a nandroid backup of cm7
2.flash or restore nandroid backup of a sense rom.
3.download msl reader from the market and run the app and get your msl number
4.goto the sense dialer and enter "##GPSCLRX#
5.enter your msl number
6.reboot
7.restore your cm7 nandroid backup
gps should be fixed.
if you are talking about the gapps with vvm fix, it will not fix your gps as far as i know. i do believe the one i mentioned above. not sure why you can't get a fix on your phone.
Ok it downloaded into rom manager so now press install from sd card. Sorry about all the questions just though we arnt suppose yo use rom manager.
yeah you just flash it like normal and you can flash it on top of your existing gapps file if you have it. just wipe cache and dalvik cache.
