what if i don't have a sense rom?
I think this is why the fix is not working for me, Ill try this and report...There's a step missing in the GPS fix instructions above. Once you've reset and rebooted in the Sense ROM, go to the Maps app and wait for a full GPS lock. Could take up to 10 min or less than 1 min. Once locked, then flash back to cm7.
Not everyone needed to do this, but some people do.
NOPE no luck.
Actually i found out what the problem was, I was testing it too close to my router and the wifi was still on. Turned off the wifi and presto!...Hmm never done it that way. I always. Use GPS test in the market
the gps fix worked!! thank you everybody for your help
