Grand X Max + OFFICIAL LOLLIPOP UPDATE FROM ZTE!!!!!!!
TomS13VH
Go to ZTE website. Click on the x max + and scroll all the way down. There it is. And it's awesome!!!! Your current build number should be Z987V1.3.9 Android version 4.4.4 KitKat. The new update is Z987V2.2.12 Android version 5.1
ZTE GRAND™ X MAX+
THE NAME SAYS IT ALL.
Maximum display size, maximum speed, maximum camera, maximum everything!
$169.99 from Cricket
BUY NOW
Support Overview
Software Updates
ZTE Grand X Max+ Software Upgrade Instructions (English - DOC - 910KB)
Android 5.1 Software Update - Software Version: Z987V2.2.12
Download
ZTE Grand X Max+ Software Upgrade (ZIP - 867MB)
Download
I've tried this its not working , I contacted zte and they sent me to cricket who in turn sent me back to zte...complete bs
Hi I found the update thanks for the info. I can't seem to be able to update the phone. I moved the zip to the sdcard like the instructions said but when I try and update from the update from storage card it says it can't find the file. Any help would be appreciated thanks.
Yes you will loose root. Also you have to ADB sideload from recovery. Not sure why the ZTE way doesnt work.
Sorry Tom lost internet connection and asked me to finish his post.
I also tried the ZTE way with no success. So I had to use the Adb side load way through stock recovery (3e). I'm told side load though twrp also works.
Make sure you type for name exactly as is in path. Also make sure the computer sees that you're device is in side load. You do not need to rename the file.
If you need help or want a walk through either post here or pm Tom.
Thanks! um where is the twrp? i was looking cant remember where i found it the stock rom for me does not have a reboot into recovery option, just says reboot
Do you not have twrp recovery installed? If twrp is still installed on your phone just hold power to bring up the menu and select reboot then right after you press reboot hold the volume up button until you enter recovery.
