Lordvincent 90
Mounted my phone in storage mode via cwm and PC says my 32gb card is 30mb. Also says raw format so I'm guessing it is SD.
Probably a safe bet
Ok, so I've gotten past partitioning the sd card, but when I go to the CTmod section I can't find a working download link. Can I use my phone as is without the CTmod? I'm not sure that partitioning sd card worked either... it said "done!" but when I turn my phone on it doesn't seem to have changed anything. I'm a bit of a noob, but I don't want to have to learn tons of technical stuff, I just want more space on my phone :/
You don't HAVE to use ctmod. There are a few other roms that support extended storage as well. Cm7 is a prime example.
Flash these zips in order, and install the app at the end of the list for the full list of themes available for use with theme chooser.
Cm7
cm-7-HROARK-beta5.
Katokernel-ext
katokern_b0.4_cm7-ext
Adreno Drivers (improved graphic performance)
cm7-b5-update-Adreno.zip
Theme chooser
http://db.tt/9Ux6mzEx
Theme chooser themes
https://play.google.com/store/apps/details?id=com.jrummy.list.tmobile.themes
So I got everything all downloaded and installed and works great! Just one last question... How do I make it show the bar with icons at the bottom of the screen?
Still trying to figure out what kind of theme I want. lol
this is great I had a nearly flawless root and it's my first time.
After resyncing with the Play store and rebooting, I still cant seem to download anything, but I'm getting texts and I have service.
EDIT: After backing up and rebooting again I'm getting downloads but very slowly
The play store is likely just updating. Once it finishes it will download as expected
it could also be slow because your contracts and accounts are syncing
Also, welcome to Android Forums![]()
I've installed a few useful apps but I'm new to them all:
CPU Master :thumbup:
Battery Saver :thumbdown:
Smart Profiles :thumbdown:
CPU Master free(why both?)
SD Booster (def saw a difference)
Links2SD - there should already be a tweak that does this for you by default
Titanium Backup
Busybox free (no idea what Im supposed to do with this) - busy box is already installed
Cachemate :thumbdown:
go to settings> applications> running (tab)
At the bottom, what does it say for ram? (free and used)
