Worked perfect! Iwas back up and running in about 10 minutes. didn't reflash just restored a nand backup. is there a cwm recovery that will work for the optimus m?
Ok, so I followed the instructions but when the phone rebooted it just stopped at the LG screen and keeps blinking now...no recovery menu. Any thoughts?I have received like hundreds of pms from a lot of people telling me to get their phone out of Fastboot Mode. Well from now on people wont have to wait for me to help them, they would be able to do it themselves.
1) Setup
Download my fastboot files here.
Unzip the files to your C:\ drive.
On your C:\ drive you will see a folder named Fastboot after you unzip the files. With some files and folders on it.
Now double click on LGUnitedMobileDriver_S497CA20_WHQL_ML_Ver_1.0 to make sure that drivers are installed. The file doesn`t show any interface, so just wait 5 minutes then continue with the guide. Picture below show contents of folder and files.
Now that drivers are installed; connect your phone to the pc. Most of the time the computer will install the drivers for Fastboot mode but if it doesn`t I`ll tell you how to do it. If you saw that the computer installed the drivers then skip to step 2.
Right click on my Computer. Click Manage. Then on the left bar click on Device Manager.
Now just follow all the images below to install Fastboot drivers.
2) Usage
Now that you have the Fastboot Drivers Installed. Lets continue with all the commands.
Open Cmd and type or copy and paste these commands ONE BY ONE:
Code:cd C:\Fastboot\android-sdk-windows\tools fastboot erase boot fastboot erase recovery fastboot erase system
Now we need to flash recovery via Fastboot. Type or copy and paste this command on Cmd:
Code:fastboot flash recovery C:\Fastboot\Recovery\recovery-RA-optm-2.2.1-GNM.img
Then type this on Cmd to reboot to recovery:
Code:fastboot reboot
Now your phone will reboot to recovery. All you have to do now is to install a rom and your phone will be back to normal.
Hope this helps.
hey everyone! If you cant get out of fastboot after typing "fastboot reboot" make sure you unplug your usb chord before the lg screen appears after the screen goes black.
Hope this helps! =D
[COLOR="DarkOrchid"]i fallowed all the instructions but after pasting "fastboot erase boot" it stays stuck in < waiting for device > and its been like that for the past 20 minutes.
the phone version is right, everything else is where is supposed to be installed.
what am i doing wrong?[/COLOR]
Ok. So I got into fast boot mode some how today. I was doing something with trying to re-flash recovery (going from CWM to GNM's recovery) and it went into fast boot mode. I have XP and so my options are slightly different than yours, but I was trying to follow along. When I got to the point that I select the lgandadb.inf, and then select ok I get an error that says "The specified location does not contain information about your hardware." I tried some of the other drivers in there with the same results. Any thoughts on this?
Thank you Joneidy for that guide. It saved my phone!
