I think I might leave well enough alone, unless you advise me going back in. Other than the radio, there are only the four files you need to install if you go the manual route, right?
I'd assume the radio must have worked from the earlier attempt, so maybe by going and doing the secondary zip folder independently I managed to ice the cake without even knowing it?
Hammerhead is for the N5 so if you could confirm, that's you're phone, we can look at other problems that might be happening.Hi I'm getting stuck at step 9 it says FAILED (remote: flash write failure) my LOCK STATE is unlocked and this is the command line I typed ./fastboot-mac flash bootloader bootloader-hammerhead-hhz12d.img
Any ideas what is wrong?
.Daaanng.....I didn't know that!!! I leave my bootloader unlocked so I can do stuff in case something goes wrong, but I didn't know it left my device vulnerable if lost/stolen. When I read this I tried it out to prove you wrong but you were right. I powered off. Booted into recovery. connected to pc. adb pulled file from my phone to pc and read them on my pc,...without ever once having to enter my PIN (so thief could easily do the same).As far as re-locking the bootloader, I keep mine unlocked because it can give you some recovery options in case things go awry (i.e., you could soft-boot or flash a custom recovery to poke around in your system to possibly fix the problem or recover files)--amongst other things like being able to take a full device backup (again, via the custom recovery).
Keeping it unlocked though would allow a nefarious third party to also get in to the guts of your device and retrieve your files, too, using the custom recovery method I indicated above.
That matches what I found when researching Android encryption following the whole Apple vs FBI thing. If your PIN/Pattern/Password isn't required before the Android system finishes booting, then the system uses a default password (literally, "default_password") to decrypt at boot time. After learning that, I made sure to tick the option to require my unlock code at startup.Not researched this fully myself, but this has some good starting info:
