App killers aren't recommended for GB and up and killing an app that's just going to start up again is going to hurt battery.
My experience with battery savers: just turn off the screen and wifi when not needed, otherwise they just cause other problems.
Default governor would probably be best (that's why they make it the default), otherwise Google is your friend.
When you delete caches, it takes a couple days for them to build and performance/battery to optimize.
The NC is really old hardware. If you need better performance, try a Nexus 7.![]()
I get better battery life with wifi turned off during sleep. (Wifi settings... menu... advanced)
Some roms require leaving wifi on during sleep to prevent SOD (sleep of death) problems, which require powering completely off and back on... not fun.
Good luck finding a user's guide. Every rom/every device is different, then there's CM7, CM9, CM10, etc.
I'm not familiar with those settings. I prefer to install roms that are already optimized.
Mirage isn't too bad: http://forum.xda-developers.com/showthread.php?t=1344873
Plan "B" would be this: http://forum.xda-developers.com/showthread.php?t=991276
I'm also not a fan of the Nook Color. It's old and slow and waaay under powered. I got rid of mine more than a year ago. The Nexus 7 tablet is nice.![]()
I see no reason why an app is trying to modify mnt. There's no reason for the average user either.
Most folders are read-only until you change them to read/write. I use root explorer, but there are free root-only explorer apps that might also work, like ES explorer. They convert the 0777 permission to words meaningful to humans.
The sdcard should already be read/write, allowing you to make folders. I've had to mess with system/media, data/local and boot folders (after changing to read/write), but mnt is a system folder, for mounted partitions/devices I think.
