Thanks i have it now after using opera:thumbup:
Yea, Opera seems to be the only phone browser that downloads everything correctly. Not sure about chrome though.
And Firefox :thumbup:![]()
just opera, dolphin, stock, and skyfire.I was looking at some post that says we can install sony xperia walkman player . Is this true , if so how can i flash it correctly . I keep getting upgrade status 0 installation aborted or something like that .
I use dolphin and never have problems
hmm i made a nandroid backup and the OP says that it will use about 2GB. mine only came out to about 950MB. I have a 2GB external sd card so i was a little worried about making the nandroid backup but now im left wondering whether the OP exaggerated or my insufficient memory space made it screw up? also on the recovery i saw something about sd_ext not found but in the end it said back up complete. i followed the instructions to the letter so i know i didnt mess up
Do you always have to press 2nd-Init Recovery first every time you start the app?
If you have a fresh system, then yeah, it can use as little as 1GB. It really depends on how much you have saved on your internal storage. I will update the OP.i made a nandroid backup and the OP says that it will use about 2GB. mine only came out to about 950MB
Im rooted on e and get a success toast but judt normal boot
Yeah... If i hold up and power it boots, blackscreens at metro logo, auto boots at first button touch.
If i tap power, repeatedly tap up as it boots... Same thing.
Press no button.. Lg logo flashes twice, lgmetro boorscreen goes to metro logo. With google now installed it boots to the system updating popup but no further. Vibrates if you long hold home button.
It seemed in another thread that your busybox wasn't installed correctly. If you got that fixed, it will probably work now.Im rooted on e and get a success toast but judt normal boot
