im still tinkering with e and finally got the guts to try this and it worked, even made a backup to external sd.
yet for some reason cant do a nandroid because it gives the busy box error, but the backup in 2ndinit worked fine
You should be able to rename the "1970" dated backup to something better without any problems. Though, I recommend sticking to only letters (A-Za-z), numbers (0-9), and underlines/dashes.
So replacing 1970-01-07.19.00.59 with 02-09-2013.19.00.59 or fresh-root.19.00.59 should work? Trying to know what Im restoring to in case more than one backup.
Or how about something as simple as fresh_root with no numbers at all??
Think you'll break MD5 sum....
It can work. I've done it myself before.Or how about something as simple as fresh_root with no numbers at all??
Nah, you can rename the folder just fine, with the phone, windows, Linux, etc.
Parse error
@Spdfreak34
The backup method in this thread backs up to an archive file named system.ext4.tar for the system. You could open up the file on your computer (might require a special program). If it's LG, then it should have a lot of files that start with LG in the /app folder (like 20 or 30 files)
Is it always system.ext4.tar? The backup I have is ext3, but it could be from my HTC (incredible 2).
Not 100% sure, but I think it does add those files there. It has those file names in it's data directory.Does this add files to system/xbin ?
I just noticed a recovery.tar and recovery.sh seeming to pertain to different phone
AVOID "Reboot Recovery" in the Menu options. It will factory reset/erase your phone.
