brotherswing
Android Expert
Update wiper? My curiosity is piqued!
flash_image_recovery_/sdcard/"recovery.img"(return)]
Not to worry. Try the VM670NH_recovery.img or the new "Touch Screen" recovery( allows you to use either the touch screen or the hard keys) they can be found here http://androidforums.com/optimus-v-...t-guide-updated-03-09-2012-a.html#post3542089
For a really good guide for all your recovery and ROM install needs go here http://androidforums.com/optimus-v-...tory-reset-your-rooted-phone.html#post3263770
Which version, 1.2518.6 or 1.2518.4?
The Xionia is great for the Froyo ROM's but the VM670NH and the "Touch Screen" recovery work best for the Gingerbread and ICS ROM's (I suspect one of these are what you really want to install).
If you want to install A Gingerbread or ICS ROM just put the required recovery on the root of the sd card and install it like you did with the Xionia, It will replace the Xionia.
EDIT: Make sure you type in the name of the recovery in the code exactly as it is on the sd card. Hint: You can rename the recovery's to just recovery.img to make it easy to get it right in the code.
It's up to you as to what ROM you want to install, but you need the proper recovery for that ROM.
Make sure you make a backup of your system in the recovery in the "Backup and restore" section,select the backup option (this is called a nandroid backup).
Read this thread http://androidforums.com/optimus-v-all-things-root/500639-get-your-spoons-out-ics-almost-frozen.html
I think the only thing that doesn't work is the video portion of the camera. But there working on any an all problems as there being made aware of.
The Touch Screen recovery is the recovery to have.
You should make sure you make a nandroid in the custom recovery before you try to do anything else on your phone.I did do the backup as it said to do. This phone is my wife's. I already rooted my phone over 6 months ago (same phone). I think I used this method HOW TO: Root Optimus V (Virgin Mobile) - xda-developers and the recovery is something else, maybe stock? It doesn't have all the options of what I just put on my wife's.
Can I put the recovery image that is compatible with ICS and install ICS on my phone? I don't want to do it on my wife's she doesn't like change.
The BACKside is the best ROM out there for the V. It is amazing all the things you can do to it.
You need to check it out. Go to the BACKside thread and have a look around.
You'll end up having it on both phones.
