AndyOpie150
<strong> <a href="http://androidforums.com/optimus
Where is the ROM? is it in a folder?
If you can see it on the sd card with your PC it's there.
When your in the sd card from the recovery you can loop around when scrolling. It's there.
Actually it's not showing ANY of the zip files. The gingerbreak zip file is still on there, I can see it with the pc and androzip.Are you choosing "update from zip?" If so, that's what's wrong. You need to choose "select zip from card" or something like that. The first option looks for a specific file name, the other lets you pick the file.
browse into the download folder, it might be hiding there.
I didn't even see the recovery.image listed. It is on the sd card still, right?
It might be a bad zip file. Before you waste bandwidth re-downloading it on your phone, do you know what md5 verification is? A quick Google search should get you what you need to verify your file is good, and has no data corruption. You should find the checksum where you originally downloaded the rom from.
Dude, you just downloaded the source code. No wonder it took so long. It's a build it your self kernel kit, some assembly required. It isn't usable in it's current form.
That's why it didn't show up in the recovery. The ROM download should be a zip file.
Stays zipped on the sd card.
