mkbkr1
Your welcome, glad I could I could help. Just make sure you only install roms designed for our phone. Also, read the thread for the rom you want to install, some of them require a different recovery than one I included in the tutorial. You can still flash the new recovery from the terminal emulator just as you did the first one.
su(return)
flash_image_recovery_/sdcard/xxxxxxxx.img(return)
with the xxxxxxxx being the name of the recovery you wish to install. Make sure to type it exactly as it appears on your sd card. or you can rename the recovery to something easier like arecovery.img, for example.
Follow all directions for installing as per the developer for the rom you want, some of them (cm7 roms) require the gapps (google apps, market and such) separately. And most important, DO NOT USE THE FACTORY RESET IN THE PRIVACY MENU ON THE PHONE. Do all your wiping from the recovery. If you have any questions on installing a new rom or do not understand a step, please ask before trying. It is much easier to answer a question than to try to restore a broken phone.
su(return)
