Did you remember my advice on how picky the Gingerbreak .apk can be towards SD cards. Be patient. Be careful. Be thinking. Gingerbreak will not mess up your phone. I have a paper weight because I messed up using SuperOneClick. Take your time and go thru the checklist that I gave you in the last post of your thread:Support freeing space. It will work. Try to find the stock 2g SD card, reformat in your phone then download the apk and try again. Also you have to power off and power on your phone after each failed attempt(this is called rebooting). If it does not work on the next try after reformatting,Reboot and try again(if it doesn't work after 12min,pull battery(this will be the same as rebooting)and install battery,power on,and try again. If for some reason it doesn't work on the third attempt, Reformat the SD card by inserting it in your PC. go to start/computer/right click on SD card a window will pop up. select format. another window will pop up. Select restore device defaults, then select start. when it's done put the card back in your phone and start over. remember to reboot at each failed attempt. This will not mess up your phone but it will eventually work. It worked for me after I reformated using my PC.
