Root (GUIDE) Unbrick LG L70 No Download Mode No recovery mode, No Fastboot
I download aboot for my mobile d325, but when it finishs I still can't enter in download mode, any help abt that?
In the 7th step ... what did you mean by "then type your password" ... I dont have one HELP
Is it solved yet? I too faced the same as you did.
When I get to the step where you type ls /dev/sd* I only get entries with the sda prefix (neither sdb or sdc), is there something I'm doing wrong or does this just not work for my problem? I am using the virtual machine method.
this is all i get now, pc doesnt detect it, atleast i cant find it, when i try to get into download mode it says download mode, hold volume up...etc but then those lines appear and nothing happens....lol idfk what to do anymore iv tried everything
[Quote = "VillaRuizHN, post: 6971984, miembro: 1840016"] TE amoooo !!!! ♥ no sabes de el susto que me di me funciono Perfectamente !! :): Thumbsupdroid :: Thumbsupdroid:
utilice ubuntu 13.10 en vmware 9.10 :)SOS LO MAXIMO !!!!! [/ quote]: D: D: D: D: D: D: D: D
Instale Ubuntu en Vmware luego instale gdisk el cual encontré en google, ya instalado hice el procedimiento y me funciono a la perfección.
Suerte!
could you do me a favor and give me images with steps of the guide for the LG LG L70 l70 unbrick No Download Mode No recovery mode , not Fastboot . It is that we did everything but still only black screen flashing without logo lg and unable to enter the download mode , Greetings
The same, only detects sda, the hard drive of my computer, I need to repair my phone. You managed to repair it?
Ayuda! intento seguir el tutorial pero no avanzo después del primer paso, cuando escribo ls /dev/sd* solo detecta unidades de discoduro internos sda, intenté con maquina virtual, una pc computadora con linux instalado y con un un linux bootable desde CD y NADA, no detecta mi teléfono por linux, sin embargo en windows si lo detecta como qhsusb_bulk.
AYUDAAAAAAAAAAA
Does flashing the phone with the aboot file re-lock your bootloader? My apologies for the dumb question, im fairly new to this kind of stuff.
I finally fixed my lg l70 d325 using @Alexdream 's method but instead changing aboot.img file i replaced my laf.img file,it worked,if you cant find files relevant to your device you can extract them from your kdz file.
Download kdz files for d325 and d320 models from here - http://lg-phone-firmware.com/index.php?id_mod=52
Download lg extract from here - http://forum.xda-developers.com/showthread.php?t=2600575
files might be saved as bin files just rename them with file extension .img
if you are having troubles connecting your device to Ubuntu use Elementary OS
Download Elementary OS from here - http://kat.cr/usearch/elementary OS/
Hope this helps Download laf.img boot.img and aboot.img files for d325 from below
