VillaRuizHN
Member
my Tutorial
based in this Guide!
the file name correct and the file (aboot.img) is in the desktop but the error still running!!!maybe the file name is not correct, you should check spelling names corrections
it does not show anything, so vibrates and then todoes it shows the lg logo????
aboot.img for D320naboot.img for D320n? Anyone?
it just vibrates . shows nothing , I can not do anything with it , no download mode, only vibrates when I try on, then offcan you go to download mode ?????
ya resolviste ese error amigo me puedes decir como ?any help with this error ... Problem opening / dev / sdb for reading! Error is 123 ... after putting the command ..sudo gdisk -l / dev / sdb
What variant of the l70 do you have? Is it still able to boot normally, or is it bricked. If its bricked, borrow a windows pc. Get lg flash tool, and the latest .kdz file for your variant. Connect it to windows in download mode, and open lg flash tool and use it to flash the .kdzWell after all this guide, now ubuntu doesnt detect my phone, and the phone displays.
DOWNLOAD MODE
Loading .......
Press the volum up key until you see the download screen.
Any suggestion for this? I want to ubuntu detect the device again, please.
Thank you so much, but the problem is that it was detected before too in windows and now neither detect it , this PC has the lg usb drivers , and the device still displaying download mode.What variant of the l70 do you have? Is it still able to boot normally, or is it bricked. If its bricked, borrow a windows pc. Get lg flash tool, and the latest .kdz file for your variant. Connect it to windows in download mode, and open lg flash tool and use it to flash the .kdz
I have a d320n so i cant give you my aboot. Can you even get into recovery. Re install the usb drivers just to be safe. If you have twrp, and can get to it, use it to mount your phone as storage so you can copy files to it for flashing or whatever. Im not sure wgat use it is but it come in handyThank you so much, but the problem is that it was detected before too in windows and now neither detect it , this PC has the lg usb drivers , and the device still displaying download mode.
My mistake (I want to believe) was that in the rush I put the aboot.img for ms323, and this phone is d320.
After all this, I extracted the aboot.img from the latest .kfz for D320 and I want to put it instead of the first one.
And yes it's bricked.
just reinstalled the drivers in windows and neither detect it as storage, ubuntu same thing. Only displays the icon of charging but doesnt charge anything. And I mention again, after doing this (puting the aboot.img) stops detecting it as storage.I have a d320n so i cant give you my aboot. Can you even get into recovery. Re install the usb drivers just to be safe. If you have twrp, and can get to it, use it to mount your phone as storage so you can copy files to it for flashing or whatever. Im not sure wgat use it is but it come in handy
Can you reach recovery?just reinstalled the drivers in windows and neither detect it as storage, ubuntu same thing. Only displays the icon of charging but doesnt charge anything. And I mention again, after doing this (puting the aboot.img) stops detecting it as storage.
Check in windows device manager the COM ports. Does the phone show there? If so we can save itjust reinstalled the drivers in windows and neither detect it as storage, ubuntu same thing. Only displays the icon of charging but doesnt charge anything. And I mention again, after doing this (puting the aboot.img) stops detecting it as storage.
I just tried the fastboot, but I it's not clear to me how to do it because in this way displays the downloadmode (where is it stuck) maybe Im doing it in the wrong way.Check in windows device manager the COM ports. Does the phone show there? If so we can save it
Did you ever flash the .laf file to replace download mode with fastboot? If not, you wont be able ti get it unless the phone shows up. What happens of you try to boot the phone normally? Try another usb cable?I just tried the fastboot, but I it's not clear to me how to do it because in this way displays the downloadmode (where is it stuck) maybe Im doing it in the wrong way.
In device manager doesnt show up.
