Root [GUIDE] Unbricking/Returning to Stock Optimus M Plus
sammyz
LG Whiz Kid
First to get rid of confusion, this guide is strictly for the Optimus M + NOT the Optimus M (old)
Optimus M + Model#: MS695
Image:
Optimus M (old) Model#: MS690
Image:
The unbrick guide for the Optimus M (old) MS690 is here: http://androidforums.com/optimus-m-all-things-root/364080-unbrick-phone-lg-screen.html
Now that confusion is gone of which phone is yours, lets continue with what you need to unbrick this bad boy.
Note: The files I am using do not use joneidy's unbrick PM guide files. LGNPST will not work with the DLL that LG supplied us.
You will need to download everything in this mediafire folder: Free Cloud Storage - MediaFire
Or everything in this quote:
Once you download all that, extract it.
Step 1: Install B2CAppSetup from the LG folder
Step 2: Open LGMobile Support Tool>Install USB Driver>Select Carrier>MetroPCS>Double-click LGMS695>Reboot after installation is done.
Plug in phone now and make sure it is in emergency mode. Put it in emergency mode by following this:
What I did is I pressed volumen down, search key and power button, as soon as I saw the LG Logo a let go the power button and search buttong but kept volumen down pressed and a different screen showed up, it has the LG Logo on top and it says "Download is in progress. Do not disconnect cable."
Step 3: Open the KP500-Utils-EN-v0.4.2 folder and then Open "Open"
Step 4: Choose J
Step 5: Type MS695>Press Enter
Step 6: Type the complete location of MS695ZV4_11.S4_11.P3027.cab
Example: You extracted it to your Downloads folder it would be:
C:\Users\%USER%\Downloads\KP500-Utils-EN-v0.4.2\MS695ZV4_11.S4_11.P3027.cab
Press Enter
Step 7: Copy and Paste this: MS695ZV4_11.S4_11.P3027 >Press Enter
Step 8: If a prompt comes up asking to restart, press restart. Once it finishes you are unbricked. Enjoy :D
i followed directions exact. it got to the very end of the process and it told me there was a fatal error during the update,
this is the error that showed up:
STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
My phone wont turn on at all. not even to go into download mode. It never even got stuck at the LG screen. Its just completely dead.
I was in Clockwork recovery. I went to flash a rom but chose the wrong one (I had Samsung roms saved from my previous phone) and it installed and just shut off. Now it doesn't turn on at all. I did everything I could, pulling out the batter, trying to go into recovery manually. Everything, but it just doesn't wanna turn on
There are no roms for the optimus m plus (yet).....what were you thinking????
Did you try to get to emergency mode?
I don't know ! I just thought maybe if I modifed another rom from a different, changing the source code to match the lg optimus information maybe I can flash it without any problem. I guess I was wrong ^~^. And no, how do you put it in emergency mode ?
My OP says how someone else was able to.
Also next time if you're going to flash a rom, at least flash something from a phone that is very similar by hardware....flashing from a completely different brand is asking for a brick.
Ohhhh, so how do I go into emergency mode ?
No. I even plugged in the charger an not even the screen turned on to show the battery charging thing
FLASHING WITH ROM MANAGER, PLACES THE KERNEL OF ANOTHER ROM ON.
DO NOT FLASH OTHER PHONES ROMs, THEY HAVE DIFFERENT boot.img's//
You sir, now have a brick. There's no way to fix it. Better start crying to corporate~
