gbiggie
La patience et le pardon
The update for ZVD has been release.
Download the LG Drivers here:LG _USB _Drivers_All_4.9.7.zip - File Shared from Box
Then download and run the LG update tool here:http://csmg.lgmobile.com:9002/client/app/B2CAppSetup.exe
If you have an external SD card in your phone remove it now.
Plug your phone in(Choose Internet Connection Mode) and the update tool will check your phone. The "Start Updating" will turn red when the tool is done reading the phone. As shown in the picture:
Click "Start Updating" and phone will update within 30-40 minutes.
Once updated if you wish to root proceed:
Prior to rooting ZVD version do a 'Factory data reset' on your phone: Settings-Privacy-Factory data reset-Check the box to "Erase Internal SD card"-then select "Reset phone".
Download the root for your Computer operating system:
Windows:http://vulnfactory.org/public/LG_Esteem_Root_v2_Windows.zip
Linux/OSX:http://vulnfactory.org/public/LG_Esteem_Root_v2_Linux_OSX.zip
Unzip the files.
Put your phone in USB debugging: Settings-Applications-Development USB debugging
Plug your phone into computer -Run the "runautorun.exe"
Select "Internet Connection Mode"
Open the root file you downloaded and extracted(unzipped) execute:
Windows-run.bat
Linux OSX-run.sh
CMD Window opens follow the prompts on the screen.
Thanks to Android Forums - View Profile: jburt for the video on the root process
LG Esteem | ZVC Root Complete Tutorial Walk Through | 1st on Youtube! - YouTube
Disconnect the phone from the computer.
Setup your Gmail account and proceed to the "Play Store"(Market) and download ROM Manager(https://play.google.com/store/apps/details?id=com.koushikdutta.rommanager)
Open app and "Flash ClockworkMod Recovery"
Then "Backup Current ROM"
One thing to keep in mind-if you flash any ROM,Kernel, it will overwrite the fix for the power cycling(random re-boot) problem in previous SW versions.
Until all ROM & Kernels are built from ZVD source there will be problems
Big
to:
All you ROMMERS & Themers
rooting god djrbliss(Dan Rosenberg)
jburt for the root video
Testers: Fuzzy13,djlucklu,mrpnut,killayogibear
Unzip the files.
Windows-run.bat
Linux OSX-run.sh
Big
