Help Handcent Timestamp incorrect
Rube8514
Just recently, the Handcent app will be incorrect when showing the timestamp on text messages....its not all the time though...it will be right for a few, then be off a few hours later on.....is there a fix for this, or does the creator need to resolve this?
try clearing the cache for the app and see if that helps. settings>apps>handcent>clear cache.
besides Oceans suggestion its really a Handcent issue and not an Evo issue. So you may need to contact them and give them as much info as possible to help them figure out the issue.
