o i forgot also when i went into that bootloop after freeing from the loop with the lgpnst it went straight to the test mode . .Mine happened while updating to ZVD BUT I know what caused mine. USB died during upgrade and I had to resort to the emergency phone book recovery option in LGNPST which will automatically throw you in test mode.
This is the lone clue I had in trying to figure the cause. The system detects a threat and closes it self off for protection.
I wonder if it was some type of software that LG was testing and wanted to test it on low to mid level devices before going out to the big boys. ???
so lg what's up with the zve since we got zvb zvc and zva ?????One thing i strongly recommend is that if your not in test mode now, best get a screenshot of your MIN because its not always the same as your phone #. Itll be easier to reprogram with that number.
no its not always the same,mine isnt,but i hate the test mode!!! its like the ring of death lol and every other device pops up with something,its a conspiracy to me lol,i wonder if the obama phones mess up lol
When metro started most MINs were the same as the phone number. As they got bigger they acquired more prefixes (the first three numbers after the area code) and for whatever reason these new numbers didn't match with their MINs. Then I found out that your phone number/MDN is just the number you give other ppl, and the MIN is what the computer/switch/towers reads your number as when you call/text, basically just like a pc reads binary codes: you type the letter "a" but for the computer understands it as "01" (which I don't think is the real binary for the letter "a". So long story short, you dial 7275555555, and if the MIN is different the switch will read that as perhaps 7276666666. If you call your own MIN nothing happens as most times it is not a number in service because the MIN doesn't have a MIN, are you following? But in some cases MINs don't "sync" properly with given MDNs and the MIN has to be switched out with another one which means that in rare cases you'll call your MIN and someone may answer because you number was assigned a MIN which belonged to another number and was the same as that other number but it simply didn't work properly with that number so it had to be switched out.
Tired yet? Anyways, I hope you understood, if not, ask away.
i've never been in test mode and i've used gingersteem, broken out, number two 2.4 - 2.8.1, and doverted v2
