Root Having trouble trying to OC
Syv3n
Every time i try and put in the command to OC
su
mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system
cp /sdcard/overclock.ko /system/lib/modules/
cp /sdcard/overclock.sh /system/bin/
chmod 644 /system/lib/modules/overclock.ko
chmod 755 /system/bin/overclock.sh
mount -o ro,remount -t ext3 /dev/block/mmcblk1p21 /system
i get the following issue
cp: /system/lib/modules/overclock.ko: read-only file file system
what am i doing wrong? I unzipped the file when i downloaded it..
su
just put both overclock files on your sdcard and do the commands that are in your post
su
su
they both are on my SD card and when i get to the first command of
it says that error of
I hit enter after each row right? u dont just put that whole command in from top to bottom and hit enter.
That command should be mounting it as R/W
And yes each is separate
Ok well i dont have problem until this part..so what could be causing it?
You shouldn't have to do this but you can give it a try
before you do that command try
mount -o remount,rw -t yaffs2 /dev/mtd/mtdblock4 /system
And if you have root explorer you can use the directions I have in my overclock thread
Ok well is there a video on how to do this so I can even see if after i put in these commands its suppsoed to look like something? I put in that command and it just went down the line to the next # line..also why would it say that the file i have is just a "read only file" has anyone seen that before?
Well if it just goes to the next line then it worked, it wasn't saying the file is ro it was saying where you are trying to put it was ro
Is there an app in themarket I can download that shows what the cpu is clocked at to see if it worked?
The file structure where you are copying the files is Read Only by default. The first command in the directions (mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system) changes that to read/write. You should be able to copy the files then which are the next two commands (cp .........). If the file structure is still R/O, then you get an error when you try and copy them.
Once the files are copied, you set the permissions level (chmod commands) for the two files, and then set the file structure back to R/O (mount -o ro,......).
That is the anatomy of the commands. Obviously you are having trouble setting the file structure to r/w.
If you have Root Explorer, you can also set the file structure to r/w and back to r/o without using line commands. That might be a better option if you are struggling with the line commands. If you go this route, you will skip the first and last commands.
Yeah, but the first command should do that for him. I don't get it
