Root Hellppp ! Triumph wont show on computer
Rell22
I have been trying for a long time to get my motorola triumph rooted but the olny problem i run into is getting the device to show on computer. i am running windows xp , and i have downloaded the motorola triumph ABD drivers but dont know how to installl them . also i already have the recovery.img file & the cmw recovery file . just need to get my devie to show on this darn computer .. :mad: PLEASE SOMEONE HELP !!!!!!!!!!!!!!!1
Hello and welcome to the forums, Rell22.
Triumph - All Things Root - Android Forums is the area with the most rooting info for the Triumph. In http://androidforums.com/triumph-al...l-things-root-guide-updated-03-25-2012-a.html you'll see http://androidforums.com/triumph-al...od-triumph-no-root-app-computer-involved.html for a method that may be of great interest to you. ;)
I have been trying for a long time to get my motorola triumph rooted but the olny problem i run into is getting the device to show on computer. i am running windows xp , and i have downloaded the motorola triumph ABD drivers but dont know how to installl them . also i already have the recovery.img file & the cmw recovery file . just need to get my devie to show on this darn computer .. PLEASE SOMEONE HELP !!!!!!!!!!!!!!!1 . Or is there a CWM RECOVERY apk file that i can download that works like the regular app without going threw all the computer and usb connecting issues I REALLY NEED HELP. P.s i can root the phone using gingerbreak its just i dont want to root untill i can flash roms .
Well, you have to connect to a computer in order to get ClockworkMod Recovery on your phone. You don't need to root before flashing a ROM though.
So your PC doesn't recognize the phone at all?
I will check into the drivers and gwt back with you when I get home to my PC if someone else doesn't get to it first.
I remember others having issues on xp, bit I think ww got it figured out somehow. I juat don't remember the details off the top of my head.
The pc recongize the phone sometimes but it says install hardware and i tried to manually
Pick the abd drivers for the triumph that i download from this site & then it says unable to install
Hardware , ive tried everything i think & i thank you guys so much for helping me with my problem :)
Ok. Check out the sticky about cwm and roms at the top of the root section (the only other sticky besides the root guide). See if you can boot into download mode and get your pc to recognize it. Instructions are in that sticky.
If so you can put CWM on it and flash roms.
If not I should be able to get home and on my pc in about 45min-1hour and can help you some more.
my phone's usb connection was loose so i had to position the phone perfectly for a connect to be made, (i leaned it against a book), but now i assume the connection has been completely severed as I can no longer seem to get that to work either...I'm pretty sure some of the phones have a broken usb port. ) :
Also make sure you are using the original USB cord that came with phone. Although other cords fit the triumph it will not allow you to connect to a PC.
Rell22, I merged both your threads into this one. That way you don't get responses in both and have to switch back and forth to figure things out. Hopefully it helps out some. ;)
Actually if another cord doesn't work with the MT it's probably a problem with your phone. I can use any micro-usb cable with mine. And it charges/ connects to my laptop fine.
To transfer files and stuff (not using adb) on XP, I just clicked cancel on all the driver install prompts. After the last one, you should have 2 new drives showing in My Computer. One mounts as a non-accessable CD drive, the other is the SD card in your phone.
To install a recovery.img, the phone has to be in download mode before you plug it in. You'll get 1 drive called mobile.
I never needed the adb drivers until I wanted to use adb.
for that I had to use the extracted drivers that wobblethehut posted.
http://androidforums.com/triumph-all-things-root/415058-extracted-triumph-adb-drivers.html
Well I believe it was agent13 who said boot into downloader mode & see if the PC will recognize it, if not you could have the problem I had, my triumph took a header off my desk while tethered & it would no longer USB connect only charge, had to replace it.
Yes , it seems the cable i was using had a shortage .now i have a new one and i put the mt
into downloader mode and everything showed up . now im bout to switch the recovery.img files . i really want to thank all you for helping me , i truly couldnt have done it without advice you guys were givin me THANKSS AMILLION .
Hi, I'm new here, my friend is allowing me to "test drive" his triumph before I buy it, he had it rooted with a mod droid OS on it, but I wanted it back to stock before taking it for a spin, so he restocked it, it's running android version 2.2.2, everything on the phone works, calling, texting, web, etc, but when I plug it into my computer it simply doesn't see it, tried it on my desktop and laptop, no go, even installed the motorola device manager. He still has astro device manager on the phone along with the differen't mods in them. But I just need to get the computer to see the phone is connected, any advice? Oh, it does charge tho, and I'm using the same cable my friend used to root the phone and then restock it.
put the phone in down loader mode( shut it down, push and hold power and volume down),and then plug it in to your comp and see if it recognizes it.
Also, what if I want to get out of downloader mode without doing anything?
Download mode (holding volume down while turning the phone on like bmanzana said) is like a low level access "boot". It allows you to mount the phone as a USB flash drive and get at the mobile partition. That's where the boot.img (main boot when you are using your phone) the recovery.img (recovery boot, duh) the splash.img (the still boot logo) and some other stuff.
When you enter lownload mode you will see a repetitive responce saying something like "polling yadayada", affter that you plug in the USB cable.
