Okay so I'm currently running Blend ics rom, and want to go back to Blazer Rom. Qbking said its a bad idea using ICS recovery. What should I do? And idk how to work Odin ):
any questions just let me know.
please help meI miss my blazer rom so much and idk how to go back lol. And thank you!
yep...![]()
even if I'm running Fd05 I can still choose El29+cwm rogue??
You have me confused ...Where are u at right now...What Rom and what Kernel are you running at this moment right now ???![]()
I'm running Blends ics rom Fd05
Yeah its Ics and How do I get El26 cwm? i have no idea how odin works. can I just flash el26 kernel using ics cwm?
lol of course I'm rooted. I'm currently running Mijjz Blends rom and Want to switch back to Blazer Rom
i'm running the second one which is the Blendz ICS rom FD05. And Ive used odin before when I rooted my phone. I just dont know how to install el26 cwm
OK ...now were on the same page...
http://db.tt/yGwUFb1z The Link for the tar file...Copy it to your PC Desktop
...If you have Odin still on your Desktop...You have to open it up and Place the tar file (which is the kernel )...To do this Check the box in front of the PDA Box...Then click on the PDA Box and place the tar file in the box when and where it tells you to...
Then power off your phone and Hold Vol Down and Power Button together till phone goes into Odin Mode...Then hit the Vol up button and Plug it into PC with USB Cable...Odin will Recognize phone ...you will see Box in yellow with Comm and #... Make sure only Auto Reboot and PDA is checked...Once you see that hit the start button in Oden ...It will flash the tar file which is the kernel and reboot phone...When it s done it will reboot to start screen...Unplug USB your done Now you'll have the EL26 Kernel with CWM...
Now you can flash back to Blazer if you backed it up...![]()
will I still be on the ICS rom once I flashed el26 kernel or It will take me to a new GB rom?
