chrlswltrs
Extreme Android User
If you use Odin for your PC ...You will get the Yellow Triangle...If you use Mobile Odin ...You Won't...![]()
Or just use Odin from your PC, then run the app Triangle Away... No yellow triangle
Or just use Odin from your PC, then run the app Triangle Away... No yellow triangle![]()
whats yellow triangle???Oh and I have another question. do you guys know any Stock GB rom? Like Cm7, but I need a very stable one with a good battery life.
Blazer rom is great but Im getting bored of touchwiz. And I will flash Cm9 once they released Alpha 3!
I know!.
Can you explain what are modems for?? I just flashed Fd02 from el29. They said its supposed to give me better battery life and better performance???
A modem can affect the 3G/4G/Wifi speeds, GPS, and signal strength. Usually, phones handle each differently so performance is different depending on the phone.![]()
Oh okay lol can you teach me how to install different kernels???
How do I install it?? Just wipe cache and dalvik and flash??
Is there any good kernel that isnt el29?? I dont like touch recivery
Rouges gunslinger is a great kernel. Its just the standard rouge recovery, not the touch. All the tweaks are the same between gunslinger and hitman.
Will gunslinger give me better performance/battery life?![]()
Alpha 3 released this morning, I've already updated!
