Root Help going back to GB from ICS
HOW IS IT?? And how do I install it? They said you gotta have el26 kernel. I have el29 o:
So far running very smooth. Other than a notification volume bug which is very minor I don't have a problem with anything else.
Here is the install guide. Links to all the files you need are located there, including the kernel with CWM that you need to flash before flashing the ROM. Follow the directions step by step and it should be easy.
Yeah I just flashed it(: its very smooth. I finally learned how to use odin. Its so easy! Hah
Yeah, but it is worth it when you want to flash something and you won't be at home for several hours. I'm not a patient person when I could have it now for just a few bucks.
Im always at home anyways :p haha I restored to Senzation rom (: I wasnt really feeling ICS yet
I've used at a friends house during a boring get together, etc. also when at home sometimes I am in the living room and my laptop is all the way in the office and I don't want to go get it :cool:
What is it you like better about Senzation ROM? I can't imagine go backwards in OS version...
Well It maybe different to you. But It feels smoother, not saying Cm9 is all laggy. And I really like the theme of this rom.
Oh and how do I remove the yellow triangle??
There is an app called "triangle away" on XDA, but I think it only works on ICS. I am not sure how to remove it on GB.
