Root Help help me fix my lg esteem
jm1985
I tried flashing my phone and it got stuck on clockwork mod and then i download a zip file and it stop work going to clockwork now it doesnt go to clockwork mod it shows lg screen and after that it goes to a black screen what can i do to fix the problem
Try with phone off.power button + up/down vol. Keys at the same time.then it will ask to reset phone do that and see what happens.
Huh? Try to explain your situation a little better please.
Rom info, what "file" you downloaded, what caused the problem...deatailed, etc...
Have you tried restoring your Nandroid backup?
Welcome to AF, jm1985! Just wanted to let you know, I moved your thread to the All Things Root section for you. Thanks for signing up! :)
Download the LG support tool... that happened to me b4
