Root Help, I'm in bootloop (I think)
Followed the directions to go from Froyo to .595. When I rebooted at the end of .595 zip install it gave me a text screen that says "Bootloader" and then some err code and tells me it's "OK to Program". The power button turns it on and off, but no combination of power/home or anything else I've seen on the forum gets me into a recovery mode.
Am I totally missing something?
Updated to .595 straight from .588 no problem then I tried to flash Bouchigo's original crt and blue bat mod ( I know I should have checked first) Now I'm in a bootloop. I tried wiping data / factoy reset but no good. I also tried to boot into stock recovery but when I hit the search hard button I do not get the menu. Did they change that option?
Ah, thank you for the link. I'll give it a try.
Once I do this and reload using the 2.3.340 system only file, will I need to reload maderstock or will I be ready to load GB .588/.595?
You can't go from maderstock to loading gingerbread. You'll brick. You have to do it from the sbf restored .340.
You have to load .588's three part installation first, then flash the .595 build.
I went from maderstock to doing the 3 part then to 595. now im in bootloader mode with the errors as well. Am i bricked or can i rsd lite to the full 340?
somewhat of a "soft brick" some might say lol...if you are in bootloader mode then you can SBF with RSDLite
