I hear you em but it can never hurt to use super wipe. But I think too many people rely on it. I never had any issues using it in the past while doing my normal wipes.
My issue is that the advice of using multiple passes of superwipe persist.
Because "it needs to get REALLY wiped."
If the tool works for you, great.
But it was born due to an old recovery error and now contains the same error - it may on occasion say it's done when it's not necessarily.
Solution - use a good recovery.
Okay, here's what is happening... I am trying to flash a different Rom... and the process went well until its time for the rom to load.
The infamous white htc logo screen won't go away. Now all my anandroid backups are gone from the TWRP folder.
I'm stuck on a white screen with no anandroid backup...crap!??!!!?!
No matter what i do, the phone won't load pass the HTC logo screen. regardless of which Rom i flashed.
Any ideas?
Speaking of recovery...
Please boot into your bootloader via volume_down+power and then nav from there to recovery.
Plug your phone into your PC and using advanced options, take turns mounting each of your sd cards, internal and external.
See what the PC finds.
Why?
Hardware storage (ext sd) and hardware partitions (int sd) are gotten to via mount points - they look like folders but they point to hardware.
And because they're folders, if the mounting isn't done, you'll see the referring folder instead of the actual hardware.
Mounting via recovery ought to get you below that layer to see what's what.
You probably have a bad flash - heck, you could even have the rare case of a corrupted recovery.
If in doubt, fastboot flash TWRP 2.6.3 from your PC on that last bit.
Post back if you're still not able to get your backups, mounts or the bootloader.
