And it goes whitescreen when you try to go into Recovery from bootloader?
Do you have... or know where to find this?The Captain gave some instructions on how to clear things when dealing with that rom.
Did you see his post?
Exactly. Bummer.And it goes whitescreen when you try to go into Recovery from bootloader?
Result:I don't remember, sorry, you'll want to ask him.
But try my fastboot command in the post above this one anyway.
Could give us some clues.
That sucks...That strongly suggests that either your ram is completely hosed - or you got a bad download of your recovery file - or it got corrupted later.
What that command does - boots your recovery image from the PC storage into the phone ram.
Try to download it again.
That sucks...
Download the ...what? The recovery file?
Chin up.
Stuff happens while playing under the hood.
Breakage happens but it's rare.
I'll be surprised if it turns out to be not fixable.
I know how you feel - we've all been there.
I am s-off.First thing I need to confirm is whether you're S-OFF. If so, then you should VipeRUU so you have a clean slate to start with. At this point, that's the first thing you should do.
Once that's done, let's confirm you have a working device, and then we can get TWRP back on it and get a custom ROM set up for you again.
Nope! haven't used Superwipe in a long while.Did you happen to use the Superwipe zip from yankees2450's thread?
I didn't check your link, but there's only one VipeRUU I know of.I am s-off.
Cap, is that the same link i post? [Viperuu] If not, could you post link.
Okay.I didn't check your link, but there's only one VipeRUU I know of.
Since I'm on vacation ... I am thinking about rooting this bad boy.
I'm doing the process one step at a time. By the way, I was surprised to know that my actions didn't really bricked my phone.
If I need help, I will make sure to give you (EM or Cap) guys a shout.
