roadkill42
Android Expert
what is these two down loads and did u ever get the 2ooo mhz oc done to for testing?
One is the boot.IMG and other is zram that can be used with earlier test build.what is these two down loads and did u ever get the 2ooo mhz oc done to for testing?
I stopped working on that for the next few days (OC) to get the source code cleaned up and pretty. Making small commits here and there. Getting it ready for primetime
@spock1134: what's the abootimg command for making a boot image, my zImage is getting too big
That's only for KitKat. He's need it for jellybean
I didn't even know this existed, I cant thank you enough for making/linking this. I've been trying to find something like this for months. How did I possibly miss this?
Hey!(So yeah, I'm SLOWLY coming back, but of course after all the good work has been done in my absence >.<)
Honestly, this sounds like my 2.1 kernel way back, when it turned out I was just really modifying the 'display text' essentially. The 17.5 k bench sounds like a 1.6 clock speed.
Well, considering I have personally recorded benchmarks at 19500+ while running at almost 2.0, I'm inclined to believe that this is an error due to something else. Especially because I have been there before, as I was able to 'clock' my device up to 2.4 before I realized what was going on. To put it extremely simply, basically all that was updating was the 'display text' of the clock speed, not the clock speed itself. So my 2.4 was really closer to 1.4/1.5 or thereabouts.Any idea what the IPC on our snapdragons are? His kernel actually could be holding a steady 2.1 and not show much improvement beyond a point simply for this reason. OC, doesn't help IPC one bit. So, coupled with such high OC, it could actually give poorer results than expected due to making more errors, and having to double back to correct them. I've had this happen on PC CPU's. This is why we have "sweet spots". If its even slightly unstable at that speed, it can do much more harm than good. The errors increase exponentially once instability is hit.
Also, I had no idea what IPC meant, and had to google it.So yeah, no idea what it is for this chipset.
So umm...I'm really excited about this. What's up with it? Thanks for all the hard work. This little $50 phone is hardcore!
Zram is done, fully working......as well as zcache (latest 3.4 version)I believe he's working on adding z-ram. It could be a min before we see any sort of progress though, I've read that z-ram can be a real pain in the arse to implement depending on what API and phone you're working with. And there's no telling what else he maybe adding with the next release. I'm sure work is in progress though.
The OC is wrong like cooldudezach said. I found my error and looking into getting it really 2+.
But so far, has anyone had a reboot at all?
How does it do when u lock both cores at 2GHz? Do weird things happen, because mines does thisi flashed it as a kernal seems to b working good so far
running for 30 mins booth cores wide open no ishues no WiFi but we all ready no this![]()
