Root Help!!!!! Lte rooted. Stuck at boot screen!!!
mykerokka
Hi I recently rooted my phone and everything was all dandy and what not until I tried to install a new bootscreen. :/ Now everytime i try to restart my phone it gets stuck at the "htc quietly brilliant" bootscreen I can get into recovery and hboot just fine but I cant actually log into my phone. Recovery cant find any backups and idk how to factory restor without getting into the phone. Help please!!!
welcome to the forums!!!!
did you make a nandroid backup? did you save it on internal or external? do you still have the rom file on your sd card? you can always flash that. if not then you can mount the sd card and move a rom file over. connect the phone via usb and in the TWRP recovery mount>mount usb storage>transfer file over.
now all you have to do is wipe and flash a rom.
what method did you try to install the boot screen? and are you speaking of a splash screen (htc quietly brilliant) or the boot animation screen?
since you can get into recovery just try to reflash your current rom as ocean advices
yes i did make a backup, when it first asked. idk where i saved it to though. and how would i know what what rom to look for what would i wipe and flash?
I tried to install it via an app in the play store. and im alking about the original splash screen when you first get the phone. (htc quietly brilliant)
do you remember the app?
so your nandroid backup should be on your phone somewhere. go into recovery and select restore. if you have TWRP then at the top is an option to look in the external card or internally. select one of those and the file should pop up on the screen.
and did you stay stock once you were rooted? or did you flash a rom yet?
As you can see, we need a lot more information in order to not only identify what the problem is, but in order to provide you with a solution.
What is your H-boot? What method did you use to root (S-ON or S-OFF)?
The more detail you can provide about what you did the better.
The good news is you can still get to recovery. Simply flashing a ROM should fix this
I stayed stock and there is no option to view externally or internally once i enter restore
I have H-boot 1.15.0000 and i think s-on
the app was called quick boot and i tried to flash a boot called android on fire
Sorry to be late on this -
NOTE: If you're coming from another build of TWRP, you may need to go into settings and tap reset defaults to reset the storage paths so that you can see your zip files.
Although not the same cause, that might be helpful here, to help you find your backup.
I am having the same problem, but I have the one x and I don't have the rom in my starage anymore and when I try and mount my sd card it gives me and error, I know the one x dosn't have an sd card but nothing else in the list works what should I do
