Root Help! Phone wont load :(
ok, so I rooted my phone using the one click root, and was uninstalling apps that i no longer use. I got brave and deleted my bluetooth and now my phone gives me an error message when it boots up :
sorry the application setup wizard (process com.androi.setupwizard) has stopped unexpectadly. Please try again.
I did a factory reset and got the same message again.
I also tried to "unbrick" my phone but when i go to plug my phone up my computer will not recognize my phone
PLEASE HELP ME :(
also, my phone loads all the way to the home screen, but only shows the status icons on the top.
what rom? sorry im kinda new to this. and i tried odin, but when i hook up my phone to my computer, odin says to please connect a phone. and the driver is installed directly from my phone, windows searched for the correct drive, and then installed it.
are you putting the phone intodownloading mode? (hold vol down+camera+power)
yes i am putting it into download mode, ime looking for the usb drivers online now and hopefully they will install correctly
