Root Help please
Tme0789
Im a newbie i have all rooted and modded on phone completely before and now my evo is stuck on the splash screen.
no matter if i try to reboot through bootloader or just turn it on ive waited 10 minutes after each try still nothing
i was trying to flash a rom,i used the root checker through market said i have root access,flowed rom instruction by factory set and wipe system/cache/data,now im stuck
im scared please help
Are you able to get into H-Boot or recovery? Pull the battery and then replace it and push power+volume down.
If you can get there, your OK.
What ROM where you on? We need more details
as ocean said what recovery do you have? what rom are you trying to flash? By looks I would say your on CW and not AMON RA.
ten minutes may not be long enough time I've had it take almost 30 minutes to boot a phone up before. I would get amon ra and wipe and reinstall.
thank you guys for your quick responses,i can get into hboot,i thought i had amon ra recovery but now im not so sure,i was trying to flash Energy
If you can get to recovery you are gonna be just fine.
What exactly did you wipe before you flashed? Did you make a nandriod backup?
i wiped the system/data/cache all at once and just now wiped the dalvik cache
and no i didnt,i knew i should have last time i tried this with my my touch fender that was what saved my ass,smh ugh
also to be clear i never even got to flashing the rom,the phone never booted back up after the wipe
Well, thats because you wiped system, which the phone needs to start up. You flash the ROM directly after wiping at least DATA, SYSTEM, DALVIK CACHE, and CACHE.
No need to reboot in between
so what do i do now will it eventually start up,because i havent even downloaded the rom,i really screwed up
ok the good thing is that you still have recovery. as long as you have that you should be fine. so in recovery there should be a usb-ms toggle that you can connect your phone to the pc via usb. unless you have the rom on your phone already. if so then no need to do usb.
so i would read the http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html. it has a flashing section that gives you the steps on how to flash a rom properly. follow that and you are good to go.
remember to always make a nandroid backup before flashing anything. and do it often as well.
also recovery is a good thing. it is when you do not have recovery and can't boot, then you can start to worry a little bit. but even that is fixable.
You wiped away the ROM that you had on there, so you will need to download another one and put it on the root of the SD card.
A nandroid would have saved you lots of headaches. From now on remember, anytime your changing something on the phone, take the time to make a nandroid.
I DID IT,lol thanks guys sooooo much,one last question where can i get the energy sensation xl sense 3.5 the link for it isnt downloading
