Are you booted into Android OS?
No I'm in fastboot mode
Grant it, if it does
I get $
That's what's wrong and why you can not change things in system......
The kernel is secure and still has write protection on the system partition.
Looks like S-OFF is starting to look pretty good huh?
Having s-off and keeping the eng hboot that moonshine flashes will remove ALL write protection and read protection.
Then when and IF boost does give us the 4.2.2 update, I'll help with that also, if you decide to s-off....
su
Any time i use adb shell it starts as $ and i have to doto get su privileges. (terminal too)Code:su
exit out of terminal
exit
exit
Then open it again
adb shell
what does it return $ or #
I'm positive it's $
you get # AFTER su, then it's secure kernel
if you get # AFTER adb shell it's unsecure
Yup,
No problem though, s-off will cure all
So if I mess up, not even a restore from a backup will help me?
It's very unlikely anything bad happens during moonshine
Very very unlikely
Oohh well I can't seem to find the file for the SV anywhere on this website, they only have HTC one, one s, one v, droid etc
Ohh ok i was just wondering
But no you don't have to do anything but follow the instructions from the website, the soju exe does the rest of the work
