keegankhaos
I just read that the HArmonia Rom will work, SO i might try and flash that one using Brians method.
If it doesnt work then i can try Negamann's.
That's a great one to start off with. I think I mentioned it at some point along with JMZ's stock ROM. If you decide to follow Remanifest's guide, make sure Harmonia is an OK starting point. His guide was written for phones that are bone-stock, right out of the packaging. Worst case scenario...you install Negamann's UNROOTED STOCK ROM...and that will get you as close as possible to bone stock. Remanifest could also make a suggestion to you for a starting ROM if you decide you want to S-OFF and follow his guide.
I flashed with Negamann's rom, and it fixed everything
started right up, and is running smoothly. YOu guys were so much help, definetely getting rep from me!
I might try that in the near future.![]()
