ive done both with sd card an w/o with new sd cardHave you tried ODIN with the SD card removed? Don't know if it'll help, but just throwing it out there.
yes... ill go thru the whole download when it reboots nothing..it dosent connect i have to power it off and get stuck agianDoes ODIN even see the phone when you connect it?
no recovery it locks up on the samsung screenhow long are you waiting with it on the samsung logo?
can you boot into recovery?
nopewere you messing around with stl5 or the efs folder ?
i get this msg
Download Start...
and still nothing...
will they know my phone was root'd?I dont think Odin can fix your phone I am sorry to say.
The only time that I have seen a phone act like yours is acting, is when someone was tampering with the stl5 / efs folder
I think that Samsung puts some type of brick maker code on the phone that detects if the efs has been tampered with and if this code gets triggered not even mighty Odin can unbrick the phone.
Thats is why I asked those questions before.
I think you will need to contact Samsung and have your phone repaired under warranty
i might get another phone to use while this gets repaired gotta see whats on clMakes me wish I bought an extra phone at Walmart on Black Friday when they were only $69. With all the fiddling I do on mine, I'll likely trash it at some point.
Just got the phone back from samsung damn i live in the same state where it shipped off too just now got it back for repair detailI dont think Odin can fix your phone I am sorry to say.
