Root Help! Too dumb for dummy proof root kit
ok where is that supposed to be shown because whenever i do it it just exits the file..... lemme see if i can try to get a screenshot vid for it......
You need to extract all the files in the root kit. They should all be in a folder called "RootOptimusM2.2.2". When you have all the files extracted to here, then move into the folder and try running the scripts in that folder.
Not move, open the folder. ;)
dddduuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuudddddddddddddddddddddddddeeeee lemme redownload extract and show you that i did exactly what you said about extracting all files. To t3084,i dont know how to change directories, what directories?, perhaps if you could elaborate?
muhaha... I was watching the vid...."WOOKWOOFWOOF...WOOFWOOFWOOFSHUDDUP!!"
To explain what was happening... when I had you open the RUNFIRST script and edit it, if you were to look at all that text, it is calling the other scripts. But in order for the script to work, it needed it's "resource files". so by only extracting the firstrun and not all the files, it could not find any of the files it needed to execute.
Though technically not the only executable, adb.exe(Android Debug Bridge) is the main tool here with it's two library files to work(AdbWinApi.dll&AdbWinUsbApi.dll),not quite sure what androidscreencast.jnlp is for.
Files with .bat are all scripted files that use adb.exe to check status of the phone and send files to the phone as well.
The other two folders contain files that the main scripts copy to your phone (with adb) and procced to execute those files(with adb) to achieve root.
Android screen cast is to view the phone screen on PC, Java must be installed and adb server must be running for this to work as well as USB debugging enabled on phone
