It all started when I was going to diable the Voodoo lagfix to make a CWM backup. I disabled it and then rebooted, and when it came back on, it was back to TW launcher and most of the apps were gone. My market is gone, and when going thru the setup wizard, it doesn't give me an option to log into Google, so my contacts are missing too. I removed voodoo first, then did the Odin process to return to stock. None of this worked, still the same, so I flashed the nandroid stock image. Now I get an error message when I boot up that says "UID's on system are inconsistent, you need to wipe your data partition or your device will be unstable." I have done the factory data wipe from CWM but can not get into the one in settings, as this just FC's. Please help!!!!!!!
Edit: I also don't have any keyboards......
