Root Help! WIFI issues
The_Billman
I am running Kings UNleashed Ultra Blakk R5, Rooted using the XDA procedure to root. I flashed Kings UNleashed Ultra Blakk R5, everythings moves at the speed of light and everything works EXCEPT I cannot scan for WIFI networks. Does anyone have any suggestions or help on this one?:mad:
try wiping cache and dalvik cache. if it still saying that then check your router. you can also check how strong your wifi signal is coming from the router by downloading a wifi analyzer app. i know that certain parts of my house the signal is weak. sometimes it is due to the fact that the signal is competing with other signals.
There was another rom I flashed that everything worked except the mail on the home screen. It was pretty weird. On another note the Kings UNleashed Ultra Blakk R5 ROM, on the swype keyboard, the letters "Z" & "Y" are transposed when using caps.
I am runningKings UNleashed Ultra Blakk R5, Rooted using the XDA procedure to root. I flashed Kings UNleashed Ultra Blakk R5, everythings moves at the speed of light and everything works EXCEPT I cannot scan for WIFI networks. Does anyone have any suggestions or help on this one?:mad:
Go back to the place on XDA forums that you downloaded the ROM from and read through the instructions. Often times, there will be some patches that need to be made manually for whatever reasons.
A zip file should be there or something about changing a text to fix one or more of your issues. I'm assuming you know how to add zips to your already existing ROM.
EDIT: Oops lol didn't see that you already solved the problem :)
I found the problem. I was trying to flash the radios first then the ROM. I did the opposite and flashed the ROM, rebooted then flashed the radio. Kings Unleashed Ultra Blakk R5 is working FANTASTIC!!!!
Hmm shouldn't have actually mattered but glad it worked. King has some great roms.
