Root help with ocing
cb3p0
Member
renamed to update
went into recovery
installed from sd, then rebooted
setcpu set to auto frequencies
still has maximum slider of 600 mhz
pleasee help ,me
If you can't figure it out from the directions given then you shouldn't be doing it. You can/will brick your phone.
i know i just renamed it update, and the proccess of installing is done, for some reason it just wont show up on the slider
if someone could help at all, besides saying that i shouldnt be doing this. other than that if no one can i think that my phone might be unable to oc for some strange reason, should i reflash my velocity rom?
You likely need to re flash the kerenl zip. Check settings > about phone and what's under kernel verison
R i dont believe it flashed correctly as mine says
dustin@dustin-laptop #39
Looks like you need to reflash the kernel
Look at the second page in the overclocking thread. Drellisdee has a post there with the kernel you need
