Help help with the PRL
i have the LG CONNECT with 3027 prl and wanted to downgrade it to 3026 because i get better internet service with 3026. I tried with qpst but it doesn work for lg connect. anybody knows any other way to do it
I'm not sure about this option so you should ask somone that is more knowledgeable before doing this!!! You can go to settings, privacy, and do a factory data reset.
In case you didn't know the new prl is out 3028 maybe that will help.
Hey guys
Got a quick question/issue
I never updated my prl list since I.got the phone I think it was 3025 or 3026 I.left because I was getting great 4g and didn't wanna mess it up well yesterday I should have stuck with my gut and not updated because now I'm 4g speeds are the same if not slower then 1x I'm on prl 3029. Is there any way to.downgrade manually or throught metro store?
Things.that used to take 2 seconds to load just don't load anymore
I tried restarting the phone and going from cdma to lte thinking it might help
Hey guys
Try this out its works for the esteem give it a shot
DO AT YOUR OWN RISK
http://androidforums.com/lg-esteem/433515-prl-post-thread-current-prl-3029-a.html
So i tried doing the qpst and lgnpst and i got no luck
just doesnt read the phone :/
guys got any clue?
i updated my plan but my 4g speeds still arent as fast, well speedtest says they are faster but when i actually do something it is slow. I am also not getting 4g in the spots i did before.
So if anyone has any clue how to do this, if possible, please let me know.
thank you
Mine was 3026 a few days ago. Now it's 3029...? Wtf. Maybe this is why i'm getting a terrible signal in my work place.
to everyone with the crappy 3029
new 3030 prl is out, i havent had a chance to test it out but i will post screen shots of results and see if it keeps going in and out
I'm on 3030 now and it's cool. Then again I never had any trouble with 3029. There is a sticky thread in the root section that shows how to downgrade/upgrade prl.
k i was able to downgrade my prl on the connect i put 3025 back on if any body needs help send me a pm ill be glad to help you out :D
