Root Help!
ok, so i have RubiX Focused and i failed to make a backup of the stock rom on the droid x because i didnt know. now the problem is, i have to go to verizon and bring my phone to switch to an iPhone so i want to go back to droid x stock. someone please tell me how to do this without a nandroid backup. P.s: i used z4root
In the third sticky at the top of the forum, there is a list of important rooting threads.
One of them is called rooler's guide. Follow the directions to either sbf your phone or use maderstock340.zip to bring your phone back to stock.
my suggestion would be to
1. Have someone shake you really hard before you make the mistake of trading in an X for an iPhone4...especially when its going to be replaced with the 5 :p
2. If you still think its a good idea, then i would flash the maderstcok.zip file...its a little more user friendly than an SBF...especially since you've already flashed a ROM, and maderstcok is the exact same process...
