Root help!!!!!
tuggyb2
im new to this, i used the revolutionary s-off stuff and that worked and then i used the cyanogen mod7 and when it booted it just was the skateboarding android and it wouldnt do anything other than show that. i did make a back up and restored it and now it works normal, but how do i get the mod to work?
Welcome to the forums!!!!!!!!!!!!!!!!!!!!!:D:D:D:D:D:D:D:D
I'm going to move you to the "All Things Root section" for the Evo 4G
If you made it to the skateboard screen then it probably should have worked OK. How long did you give it? First boots on a new rom can take awhile. Also what recovery do you have? Amon ra is the best one and I would highly recommend it. Stay away from rom manager. Did you flash the rom manually in recovery?
Once you flashed and rebooted it went to the screen with Andy riding a skateboard. Did this screen have some text you could select to get to recovery and such or was it the boot animation for CM7?
I wonder if the flash was unsuccessful and it went straight to hboot.
I believe the Op made it to the animation and just didn't wait long enough. It can take up to 30 minutes to fully boot up.
