dkl1
Android Expert
Ok. First flash of my Evo and happens that I got a "bad" .zip file! From the CWM app I selected "Install ROM from sdcard" (I think is how it is worded). It went thru all the backup and wiping etc. but after it finished with backups, it says "Back up complete! Formatting /cache... Formatting /data... Formatting /sd-ext...
Then it says it is "installing: (the ROM).zip"... Then it says it can't open /sdcard/ (the ROM) ... Installation aborted" YIKES!
What should I select now? "-Reboot system now" or?...
Dale
Dale
