greenevo4g
I messed up rooting with revolutionary and now tethering does not work. Please help. Yes, I am a noob. LOL
ok so we need more info. what is your hboot? do you have s-off? what rom are you on? and have you flashed a kernel? if so which kernel?
and what is happening when you try to tether?
Power down the phone (Turn off fastboot) then press and hold volume down button and then the power button (have both pressed down then release) you should get a white screen with andi skating at the bottom Type very correctly everthing that screen tells you.
revolutionary
supersonic evt3 ship s-off
hboot-6.16. 1002
microp-041f
touch panel-atmel224_16ab
did you install the superuser app?
Try Mikg3.0 it is way better then stock. Go to the root info sticky to get it. Mikg has all of bloatware removed. Also it has the sprint hotspot included.
