I wouldn't even attempt it on 3G anyway. Don't have that much time left in a day or my life.
In all honesty, I'm probably going to go with a free option anyway. I just wanted to find out from her specifically how the billing would work if I were to go with the "official" Sprint option (could I easily add and remove the service depending on my needs, etc.) only to be told that I could not get the service because I am in NYC and NYC doesn't officially have 4G and that it would not work over 3G. I then asked her about the scenario of having it when NYC does have 4G officially available and I was in a building that had spotty 4G coverage that I would be able to still use the hotspot even if the EVO might be switching between 4G and 3G and she said absolutely not, that it would only work if the phone was receiving a solid 4G signal.
But on the subject of "plenty of other options," are there any that I could use to create a wifi hotspot with the phone that doesn't involve rooting?
EVDO Rev. A isn't THAT bad... no streaming media but it's good enough to surf around.
Isn't it funny how we've all become so used to fast connections? I remember 14.4k (sigh).
Thanks Sikclown, I was SURE I had read that was the case. Thanks for the confirmation.
Now I just need to figure out if I can do a hotspot without paying the Sprint fee and without rooting
I was afraid of that. I've jailbroken my iphone and that was fairly easy, but I've glanced at rooting instructions of other Android phones and it sounds complicated. In fact, truth be told, I have no idea what some of the instructions even mean, so I'm a bit nervous about it.
Yeah. I guess I always choose to forget it if I can't go at max speed. I only see myself doing it with my laptop trying to either get a very large file or to stream.
I'm in the camp of I'll be saving so much after switching from ATT that most things won't matter. I don't like the $29.99 at all, but since I'd really only be using in a situation where I'd be writing it off as a biz expense, it's not a deterrent. If I do need to hotspot though, I'd only do it on 4G. Otherwise I'd go pay for access to a fast network rather than via 3G.
I wish everything was high speed, and I did everything I could to avoid the web when it was dial-up even up to 56k.
If you have an EVO and choose the HotSpot feature for $29.99mo then it is unlimited service, there is no cap!The only drawback seems to be I might pickup the 5 GB / month limit now (I was grandfathered in from an old plan with no monthly quota).
$29.99 Sprint Mobile Hotspot provides:
− Up to 8 simultaneous data sessions over 3G/4G Mobile Hotspot
− Data usage is unlimited while on the 3G or 4G Sprint network
o Off-network data roaming is subject to a 300MB data usage limitation
o MiFi and Overdrive, while Hotspots, are considered Mobile Broadband devices and subject to
3G data limitations
− Phone as Modem is available by purchasing
