I finally partitioned my SD card. Where can i get something to help me move apps to my SD card? I want my phone's internal memory as empty as i can get it. And increase RAM if possible.
what rom are you on? most roms will have a2sd cooked in. so they will be automatically moved to the card. you can use tb (main screen) and see that the a2sd partition is being used up.
if you want to be sure you can get terminal emulator and in te type su and then hit enter then type a2sd reinstall this should move any apps to the card. but you need to make sure that your rom supports this first.
if you get an error like a2sd is not recognized as an internal or external program or a bash script you will need to install it: DarkTremors you will flash this just like a Rom or kernel.
Also note that when you run it through te it will reboot the phone and it will take a bit longer to load up this is normal behaviour allow dt to move the apps its needs to and create the symlinks it needs to.
