t0ast3d
If you find this helpful or think it would be helpful to others, tip it for a sticky!
Here's a little guide I put together for you to learn basic adb commands.
I'm posting this thread assuming you already have your SDK set up
With that said, let's dive right in!
1. Turn on ADB
Go to Menu > Settings > Applications > Development > USB Debugging
2. Running ADB
Open up command prompt and type your way to the directory you have your SDK in.
Mine is in C:\
So for example, mine would be: cd c:\AndroidSDK/tools
You are now in
3. Basic ADB commands
ADB push (sends files to your phone) -- adb push c:\example.apk /sdcard/example.apk
ADB pull (Receives files from your phone) -- adb pull /system/app/example.apk c:\example.apk
ADB install (installs application) -- adb install c:\example.apk
adb shell (Begins shell connection with phone)
adb reboot (reboots phone)
adb reboot recovery (reboots phone into recovery)
adb reboot bootloader (reboots the phone into bootloader/the white screen)
adb remount (remounts the system)
4. Commands to run while in ADB Shell
cd (changes directories) -- cd /system/app
ls (lists all files in the directory) -- ls /system/app
rm (removes files) -- rm /system/app/example.apk
cp (copies files) similar to cat -- cp /system/app/example.apk /sdcard/example.apk
cat (copies files) -- cat /system/app/example.apk > /sdcard/example.apk
exit (exits shell) -- exit
Might add a little more later if requested/clean it up
Hope you learned something!
1. Turn on ADB
2. Running ADB
Mine is in C:\
You are now in
Great for noobs. I'm sure more commands will be posted after a few hours.
