Masterchief87
Android Expert
System write protection can now be disabled indefinitely with a simple shell command. You can enter it with a PC and adb shell or a terminal emulator app on your phone. If you use terminal emulator you need to run it as root or else you will get permission denied. Ready for it? Here it is.
All credit goes to @hroark13 for finding this. Here is a link to his thread with more information including how to turn the system write protection back on if you should ever want to.
http://androidforums.com/index.php?posts/7317521
That's it. Once your phone reboots you will have system rw(the ability to mount the system partition as read/write) that wont go away after a reboot or even a factory reset! Its that easy. No more need for switcher zips, scripts, or apps to get system rw.reboot disemmcwp
